Date/Time: Fri, 28 Feb 2025 01:52:56 +0000
US Consolidated Tape Exchange Activation
View Count: 192
[2024-02-06 21:04:13]
User205303 - Posts: 2
I recently purchased the US Consolidated Tape Exchange for $10 USD/month. It says the data feed is activated, but I am still getting a 15-minute delay with SPY. How can I activate the exchange in Sierra Chart to see SPY live?
[2024-02-06 21:14:36]
John - SC Support - Posts: 38259
You should be getting the data live. Make sure you are entering the symbol just as the main trading symbol alone (i.e. IBM). Do not add any suffixes or other extensions.
If you are still having a problem, then please get us your Message Log by following these instructions:
Close all of the Chartbooks with "File >> Close All Chartbooks".
Open a single chart for the symbol you have an issue with through "File >> Find Symbol". Tell us that symbol of the chart. Tell us about *one* symbol only.
