Date/Time: Mon, 05 Oct 2026 23:11:28 +0000
Some more alert help please...
View Count: 576
[2024-02-06 19:30:36]
User666015 - Posts: 66
Hi all,
I have been trying for a couple of hours without success to make an alert for when two EMA lines crossover - but only when within a certain tick range of a VWAP line, I've tried every combination of ANDs and ORs that I can think of but the alert goes off when the EMAs crossover whether within the tick range of the VWAP line or not. Here's what I've come up with:
=AND(CROSSOVER(ID1.SG1, ID8.SG1), (OR(C>=ID14.SG1-TICKSIZE*4,C<=ID14.SG1+TICKSIZE*4)))
Where am I going wrong please?
Thanks,
Bill
[2024-02-06 20:19:40]
cmet - Posts: 743
Here's a long form not using the crossover with individual long and short. Might help help you out. I'm assuming ID14 is your VWAP.
Long:
AND(ID1.SG1 > ID8.SG1, ID1.SG1[-1] < ID8.SG1[-1], ID1.SG1 >= ID14.SG1 + 4*TICKSIZE)
Short:
AND(ID1.SG1 < ID8.SG1, ID1.SG1[-1] > ID8.SG1[-1], ID1.SG1 <= ID14.SG1 - 4*TICKSIZE)
[2024-02-06 20:53:12]
User719512 - Posts: 493
The key to debug your alert formula is breaking down the pieces and ensuring each piece works.
Does CROSSOVER(ID1.SG1, ID8.SG1) work as expected?
Does C>=ID14.SG1-TICKSIZE*4 work as expected?
Then you can see you need to tweak that part to be more like what cmet posted.
AND(C<ID14.SG1, C>=ID14.SG1-TICKSIZE*4)
^^ this might be correct based on my assumptions of your intended alert. If not, it should put you on the correct path.
Then your original solution might work as:
AND(CROSSOVER(ID1.SG1, ID8.SG1), OR(AND(C < ID14.SG1, C>=ID14.SG1-TICKSIZE*4), AND(C > ID14.SG1, C<=ID14.SG1+TICKSIZE*4)))
Note, you can use multiple lines in alert formulas, but the dialog is small for that sometimes but can help readability.
OR(AND(C<ID14.SG1, C>=ID14.SG1-TICKSIZE*4),
AND(C>ID14.SG1, C<=ID14.SG1+TICKSIZE*4)
Date Time Of Last Edit: 2024-02-06 20:53:43
[2024-02-07 16:57:39]
Thank you both for your expert help, and the help explaining where I am going wrong!
I now have some time to test these approaches and incorporate into my charts.
Cheers,
Bill
