Date/Time: Mon, 25 Nov 2024 18:25:03 +0000
charts does not appear
View Count: 224
[2024-02-06 17:56:45] |
User356515 - Posts: 5 |
Hi, My charts do not appear. Please look the screen shot attached. i am not sure what to do. Thanks |
sierra probl.jpg / V - Attached On 2024-02-06 17:51:20 UTC - Size: 147.89 KB - 51 views Attachment Deleted. |
[2024-02-06 20:56:51] |
John - SC Support - Posts: 36260 |
Do not worry about the "Out of order timestamps". That can happen occasionally. With the bad data spikes like you are seeing, you will need to delete and redownload the data. Refer to the following: Data Errors or Spikes in Charts, Flat or Flat Line Graph, Compressed Graph, Errors with Date/Time Values: 2.1.2 Deleting and Re-downloading Data. (Easier and Recommended Method) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-02-07 17:08:51] |
Hi, Perfect, it's working now Thanks! |
