Date/Time: Mon, 25 Nov 2024 18:23:04 +0000
delay data for symbol mnqh24-cme
View Count: 220
[2024-02-06 15:36:10] |
Ngalylomqua - Posts: 4 |
what do i need to do to get real time?
[2024-02-06 19:11:04] |
John - SC Support - Posts: 36259 |
Before anything, you need to be aware that in order to get the real-time data for the CME Group, you need to have a live, funded, futures trading account to which you can connect your Sierra Chart software. Refer to the following for more on this: Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges If you do not have an account that will qualify for the above, then we recommend the solution outlined at the following link: Easy Solution to CME Funded Trading Account Requirement Once you have worked out the above, then the first thing you need to do is to change your package, as you need to be on one of the "Integrated" packages in order to be able to get the real-time data. Refer to the following: Description of Service Packages and Pricing: Integrated Packages To change your package, select the following link and select the package you want in the menu to the left then select the "Update/Set" button. https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation#ServicePackage To setup the data for the CME Group, follow the instructions at the following link: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
