Date/Time: Mon, 25 Nov 2024 18:46:36 +0000
trading
View Count: 163
[2024-02-06 14:19:08] |
cyhunt11 - Posts: 5 |
how to change my P/L from point to currency and how to extend the 1st standard dev of the vwap of the previous session to the current session thanx you |
[2024-02-06 18:53:18] |
John - SC Support - Posts: 36264 |
To change the P/L for most items, refer to the following setting: Chart Settings: Profit/Loss Format (List) (Chart >> Chart Settings >> Trading menu) The one place where this is different is if you are using the Profit/Loss column in the DOM. For this, you need to click on the title at the top to toggle through the different options. Refer to the following: Chart Trading and the Chart DOM: Chart DOM Position Profit and Loss Column how to extend the 1st standard dev of the vwap of the previous session to the current session
You would have to use the Spreadsheet Study to do this and get the VWAP First Standard Deviation from the time you want, and then use the MOSTRECENTNONZEROVALUE() to get that value and have it displayed across the current session. Refer to the following: https://www.sierrachart.com/index.php?page=doc/SpreadsheetFunctions.html#MOSTRECENTNONZEROVALUE_Function For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
