Date/Time: Mon, 25 Nov 2024 18:35:01 +0000
Values are not displayed in cross hair
View Count: 219
[2024-02-06 09:16:11]
User519646 - Posts: 15
Hi, While using crosshair, values are not displayed in the price scale, instead a black box is displayed. Please help me to figure it
[2024-02-06 16:19:00]
John - SC Support - Posts: 36263
There is a new coloring option for this in Graphics Settings called "Chart Values: Price and Time Boxes Text Color". Refer to the following:
Graphics Settings: Chart Values: Price and Time Boxes Text Color
[2024-02-06 20:33:48]
I tried changing color. Nothing changes. Still a black box. It is still the same. See attached. Let me know what should I do. Thanks
imageCross Hair Display.png / V - Attached On 2024-02-06 20:30:47 UTC - Size: 2.08 MB - 62 views
imageCross hair number display.png / V - Attached On 2024-02-06 20:31:30 UTC - Size: 39.77 KB - 56 views
[2024-02-06 21:11:15]
If you are using Chart Specific graphics settings for that chart, then you would need to select "Chart >> Graphics Settings" and change it in there.
If it is not the above, then make sure you are on the latest release (v 2597) and see if everything works properly for you with this release. Refer to the following for how to update:
[2024-02-06 22:05:31]
It changed color from Chart/Graphic settings. resolved. Thanks
