Date/Time: Sun, 08 Sep 2024 00:37:05 +0000
2nd Request
View Count: 235
[2024-02-06 01:55:49] |
Bruce - Posts: 46 |
Please add Transparent Fill Rectangle to the Drop down box for Use Multicolumn Rectangle Style For Price Bars Please see attached Image Date Time Of Last Edit: 2024-02-06 02:04:34
[2024-07-09 13:12:49] |
Sierra_Chart Engineering - Posts: 16292 |
We are checking on this.
[2024-07-09 13:21:42] |
This will be supported in the next release. What you will need to do is that when choosing the Multicolumn Rectangle Style, you then need to go to the Subgraphs tab and select the Transparent Rectangle Fill Top/Bottom styles for the high and low subgraphs.
