Date/Time: Mon, 25 Nov 2024 20:26:05 +0000
Activate Trial
View Count: 145
[2024-02-05 13:54:39]
User556643 - Posts: 2
I'm unable to receive SMS message (I don't receive it after putting in my phone number) and need help activate the trial.
Thanks,
KT
[2024-02-05 14:29:51]
Sierra_Chart Engineering - Posts: 17174
Your account has been activated and the usage time extended if necessary.
If Sierra Chart is running, it will automatically be activated within about three minutes. However, you may need to exit from the Sierra Chart charting and trading software by selecting "File >> Exit". And then open Sierra Chart through the icon on your desktop or through the desktop Start menu.
To get started with Sierra Chart, follow the Sierra Chart setup instructions here:
Sierra Chart Setup Instructions 1
After your Sierra Chart usage time ends you need to pay for additional usage time through "Help >> Add Usage Credit".
