Date/Time: Wed, 27 Nov 2024 04:54:50 +0000
Error when upgrading to latest version
View Count: 971
[2014-08-03 20:58:25] |
BataviaTrader - Posts: 63 |
When upgrading from v 1154 to current version I receive this error: please find print screen attached. Could you assist? Thank you in advance for your efforts. |
Attachment Deleted. Attachment Deleted. |
[2014-08-03 21:47:50] |
We are checking on this.
[2014-08-03 21:52:24] |
This will be resolved in about 10 minutes. At that time select Help >> Download Current Version.
[2014-08-03 22:26:59] |
FFTrader - Posts: 180 |
I have a similar problem except I downloaded version 1169 directly from your website (because the error depicted above) with the new spreadsheet version and now NONE of my alerts works!? See attached capture. What is going on and please point me back to version 1157!? HELP!!!!!!!!!! Date Time Of Last Edit: 2014-08-03 22:27:18
20140803 Version 1169 update issues.PNG / V - Attached On 2014-08-03 22:25:41 UTC - Size: 131.93 KB - 317 views |
[2014-08-03 22:47:19] |
Found version 1157. Re-installing my instances to this and will wait until 1169 is ready for download without a hitch.
[2014-08-03 23:08:27] |
We will look into the Alert Formula error. The solution to the problem is to use 1169 with the Old Spreadsheets. Update by selecting Help >> Download Current Version. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-08-04 01:30:32] |
Should I be concerned with new spreadsheet version as I never use spreadsheets - at least not yet?
[2014-08-04 02:07:18] |
The problem with the error with Simple alerts appears to be related to the new spreadsheets. We are going to be looking into it on Monday.
