Date/Time: Sun, 08 Sep 2024 00:37:17 +0000
difference in percentage changes
View Count: 186
[2024-02-05 08:50:34] |
User19991027 - Posts: 12 |
Iwant to see the difference in percentage changes, for example, I would like to know how many percentage points YM has increased compared to RTY (rather than how many points have increased). How should I find this indicator?
[2024-02-05 14:54:09] |
User43 - Posts: 101 |
In the "Studies Available:" look at the "Study Subgraph..." section. There you have studies to divide, add, subtract, Multiply, ... values from different studies on your chart. For your example above, With YM as your main Add RTY using "Add Additional Symbol" study. To get Percentages use one of the "Percent Change ... " studies Now use the "Study Subgraph ..." studies, to create differences, ratios, etc. |
[2024-02-05 14:56:17] |
An alternative would be of course to use SCs spreadsheet functionality https://www.sierrachart.com/index.php?page=doc/Contents.php#UsingSpreadsheets and writing your own studies in ACSIL https://www.sierrachart.com/index.php?page=doc/Contents.php#AdvancedCustomStudySystemInterfaceandLanguage |
[2024-07-09 18:52:42] |
Sierra_Chart Engineering - Posts: 16292 |
Have a look at the studies here: Using the Basic Arithmetic Studies Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
