Date/Time: Mon, 25 Nov 2024 18:45:04 +0000
Uniform Subscriber Agreement: REAL TIME DATA FEES
View Count: 579
[2024-02-04 21:45:05]
User996503 - Posts: 14
I have Iron beam as my clearing firm. Could you explain what the CME professional fees would be and if I would need to do anything with Iron beam as well? Do they have to approve the use of this data?
imageScreenshot 2024-02-04 163511.png / V - Attached On 2024-02-04 21:38:41 UTC - Size: 130.38 KB - 64 views
[2024-02-04 22:03:20]
Sierra_Chart Engineering - Posts: 17174
First, you only have to pay professional fees if you are considered a professional by the CME. Are you considered a professional?
Ironbeam does not need to do anything but you do need to put your Ironbeam account information in that form.
Date Time Of Last Edit: 2024-02-04 22:03:32
[2024-02-05 16:37:31]
I am not a professional. Am i supposed to get something that says it was accepted? What would happen if you did not fill out that info? I did fill it out but not sure if it is pending or something else. Just dont want to get charged an insane amount of money for data fees. Whats the most you can be charged, any idea? Sorry for the dumb question, very new to this and just want to make sure i am following each step correctly. Thanks!
[2024-02-05 18:03:24]
John - SC Support - Posts: 36264
You can view the status of the agreements at the following link:
https://www.sierrachart.com/UserControlPanel.php?page=ExchangeAgreements
Note that you will only be charged for the exchanges that you activate.
We see that your agreements have been accepted and you have activated exchanges. But you have not connected to your live, funded, futures trading account yet, so you will still not be getting real-time data. Your "Verified Until" date is currently showing as "0000-00-00". You can view the "Verified Until" date for your account at the following link:
https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed#Exchanges
We need to know what order routing service you are using with IronBeam in order to point you to the proper instructions for how to connect. You should be setup with either CQG or Teton.
[2024-02-05 22:21:32]
I have reached out to Iron beam. I use Apex accounts through Rithmic. I spoke with iron beam and they said i could just get all my data through sierra chart and i have service package 11, is the clearing firm just there for the order routing service? Sorry just so confused by this process.
[2024-02-06 14:47:19]
Do i need to use Iron beam? Can i not just use Sierra chart to get the Denali live data? I have package 11.
[2024-02-06 19:02:32]
You are wanting to get data for the CME Group at the non-professional rates. The CME Group requires that you have a live, funded, futures trading account, and Prop Firms do not count towards this. Refer to the following:
Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges
Ironbeam will satisfy this requirement, but if you do not want to use Ironbeam you can use another brokerage. It just has to be one that you can connect your Sierra Chart software to.
We need to know if Ironbeam is setting you up to use CQG or Teton for your order routing.
[2024-02-07 04:24:44]
They told me today Teton order routing.
[2024-02-07 16:27:44]
Once they get your account setup follow the instructions at the following link starting at Step #6:
Sierra Chart Teton Futures Order Routing: Setup Instructions
