Date/Time: Mon, 25 Nov 2024 20:29:16 +0000
Free Trial - Limited Tickers with Delayed Data
View Count: 159
[2024-02-04 20:00:18]
User219832 - Posts: 1
If we are on the free trial and we select the delayed data option, are our tickers still limited? I would like to view the treasuries (ZNH24) and can't seem to get that to load even with delayed data selected. Maybe they're just limited no matter what on the free trial but I thought with the delayed data option they were available.
Thanks in advance for the help.
[2024-02-04 20:18:05]
Sierra_Chart Engineering - Posts: 17174
Your account has been activated and the usage time extended if necessary.
If Sierra Chart is running, it will automatically be activated within about three minutes. However, you may need to exit from the Sierra Chart charting and trading software by selecting "File >> Exit". And then open Sierra Chart through the icon on your desktop or through the desktop Start menu.
To get started with Sierra Chart, follow the Sierra Chart setup instructions here:
Sierra Chart Setup Instructions 1
After your Sierra Chart usage time ends you need to pay for additional usage time through "Help >> Add Usage Credit".
