Date/Time: Wed, 27 Nov 2024 04:32:25 +0000
How to test if in LONG or SHORT position in order to call a Super Trend Stop alert sound without
View Count: 1363
[2014-08-03 18:53:38] |
User75277 - Posts: 33 |
Howdy, I am sure there is a way to do this, but I can not find what conditional to test in an alert windows (without putting up a spreadsheet). Can anyone point me to a link or give me an example that shows: IF "POSITION LONG" AND [CLOSE < SUPERtRENDsTOP] SOUND ALERT. and IF "POSITION LONG" AND [CLOSE < SUPERtRENDsTOP] then [exit position]. |
[2014-08-03 20:01:49] |
Being that you want to refer to your current Trade Position, it is necessary to use the Spreadsheet System for Trading study or ACSIL for this. Neither of these will need to generate an actual live trade signal. They can give you an alert only. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-08-03 20:02:00
[2014-08-03 23:59:49] |
I have constructed a complicated spreadsheet that identifies trade signals and takes them; in once sense, I am happy with it, but it is complicated and hard to modify. So, now I have implemented with with a series of alerts from a combination of studies that I load onto the chart. I have a green or red arrow put on the chart for entry and do not know how to put the trade into the chart trade manager. And, conversely, I would like to exit that position (even if I put in on manually) if the Super Trend Stop is hit. Is there a way to find out if a position is on and if it is long or short in the alert study box? Also, how can I find out about ACSIL and get some examples. Thanks. |
