Date/Time: Mon, 25 Nov 2024 20:38:38 +0000
2595 Light Charts Crosshair Value Goes Black on Black
View Count: 232
[2024-02-04 07:41:00] |
Acro - Posts: 441 |
Issue description: Use crosshair and then look at value and time scale to read the values shown at the crosshair. In 2590 the value text is white on a black background but in 2595 it bcecomes black on black This happens regardless of whether OpenGL is on or off I have rolled back to 2590 as using the crosshair is a key part of my processes See attached files comparing 2590 (white on black) vs 2595 (black on black) to see what I mean Thank you for looking at this |
20240204_1533_19.png / V - Attached On 2024-02-04 07:39:29 UTC - Size: 1.29 KB - 62 views 20240204_1534_01.png / V - Attached On 2024-02-04 07:39:35 UTC - Size: 1.51 KB - 62 views |
[2024-02-04 20:07:49] |
Sierra_Chart Engineering - Posts: 17174 |
Refer to the version notes about this here: https://www.sierrachart.com/index.php?page=doc/Whats_New.php#SCVer2595 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
