Date/Time: Mon, 25 Nov 2024 20:28:25 +0000
Chart trading - transmit orders only when ready
View Count: 195
[2024-02-03 08:39:49] |
User223674 - Posts: 8 |
Hi there is there a way to setup orders and not transmit them till I'm ready? With chart trading, it appears any order that is setup is active right away. I'd like to setup a limit bracket order, move it around the chart, and then when ready for it to be activated, transmit it. Or if i've changed my mind, be able to cancel the order without it ever being transmitted. I know there are confirmations that can be disabled but these dont allow the adjustments. |
[2024-02-03 10:13:41] |
Sierra_Chart Engineering - Posts: 17174 |
This is not really supported like this. But you can submit the order, away from the current price, and then move into position when you want.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-02-03 10:13:53
