Date/Time: Wed, 27 Nov 2024 04:39:11 +0000
date range to display in trade log
View Count: 1308
[2014-08-03 14:10:59]
User021827 - Posts: 174
hi
In the trade activity log, I am unable to select a date range to display.
It shows all activity from first fill regardless of dates I select to display.
Has anyone else had this happen ?
thanks
[2014-08-04 15:20:23]
Anyone ?
[2014-08-04 16:58:16]
The amount of data that you see is dependent upon the amount of data in the Trade Activity Log and that depends upon the Number of Days to Save in Trade Activity Log setting.
Refer to step 6 here:
https://www.sierrachart.com/index.php?l=doc/doc_TradeActivityLog.php#ViewingHistoricalTA
Date Time Of Last Edit: 2014-08-04 18:37:37
[2014-08-04 18:14:49]
yes
I have 120 days of data and I have set trade activity log to save 90 days in global settings.
Then I do a backtest on the 90 day chart and the activity log shows the trade activity for past 90 days.
But then I try to set the date range to only show the past week or perhaps two weeks, it still shows the whole 90 days of activity.
It wont filter it down to the smaller date range I select.
I did not notice this until after software updates in past week.
regards
[2014-08-04 18:42:04]
We cannot duplicate the problem.
Did you press the "Apply" button in the date range frame after changing the From date.
[2014-08-04 19:06:29]
yes I did
perhaps my data got corrupted
thanks for checking !
regards
