Date/Time: Mon, 25 Nov 2024 20:31:18 +0000
Alert Sounds File
View Count: 662
[2024-02-02 15:39:29] |
User360283 - Posts: 504 |
How do I see te alerts sound file and play a selected sound so I can use it in an Alert? Thanks |
[2024-02-02 17:48:10] |
John - SC Support - Posts: 36278 |
The Alert sounds are in the folder named "AlertSounds" under the main Sierra Chart installation folder. You can use the standard Windows tools to play the sound file, as they are just .wav files. Within Sierra Chart, when you select a Sound File for an Alert, you can then select the button for "Test Sound" to hear it that way as well. You can add your own sound files to the folder and use them in Alerts. Refer to the following for how to add a sound for an alert: General Settings Window: Configuring Alert Number Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-02-03 15:50:36] |
Another disappointment With Sierra I expect to find "High of Day" and "Low of Day" sound files that could easily used with the High or Low for Time Period study. But the study does not provide for having alerts for both High and Low conditions! Sierra really needs improvements |
[2024-02-04 00:02:08] |
Sierra_Chart Engineering - Posts: 17174 |
Interestingly, we have a new feature coming out, this coming week utilizing the Windows text-to-speech functionality so you can easily accomplish this. You can set a short phrase with any alert number and then it will be spoken. So you can set "High of Day" and hear that text spoken. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-02-04 12:07:38] |
The problem s that the Hi-Lo for Day study does not offer TWO Alerts one for EACH condition Hi or LO!!! The study needs to be fixed Thanks |
[2024-02-04 20:37:22] |
You need to use this study for that: New Daily High/Low Alert Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
