Date/Time: Mon, 25 Nov 2024 18:46:14 +0000
M6E has its decimals placed incorrectly showing wrong figures in trade activity
View Count: 194
[2024-02-02 15:27:01] |
NotIll - Posts: 118 |
Is this something I have to correct somehow? Or is this something to do on your side? M6E Sim trade was placed via ''Use as trade symbol only'' under a 6E Chart. Look at the price on the screenshot its showing 10902.5 should have been 1.09025 |
Screenshot 2024-02-02 162032.png / V - Attached On 2024-02-02 15:24:47 UTC - Size: 4.09 KB - 52 views Attachment Deleted. |
[2024-02-02 17:42:17] |
John - SC Support - Posts: 36264 |
If you have a different "Current Selected Service" set from when you made the trade, then this would cause this. Refer to the following: Trade Activity Log: Solving Trade Activity Incorrect Price Formatting and P/L Values For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-02-07 17:43:33] |
I have it set on teton, and have not used another. The problem is still there. Do I have to adjust things in Symbol settings? Date Time Of Last Edit: 2024-02-07 17:45:26
[2024-02-07 17:48:27] |
Sorry, we missed that you stated that this was a Trade And Current Quote symbol setup. Refer to the following for this: Sierra Chart Teton Futures Order Routing: Using Trade Symbol For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
