Date/Time: Mon, 25 Nov 2024 20:26:23 +0000
Positions Limit
View Count: 237
[2024-02-02 14:44:58]
SierraTraders - Posts: 69
When setting up a evaluation account in the global positions limit settings
the total amount of contracts is set to 5 using symbol NQ
but when the symbol is changed to MNQ it only allows the 5 contacts
any suggestions to set it for
5 NQ Contracts
50 MNQ Contracts
[2024-02-02 17:22:50]
John - SC Support - Posts: 36278
By default, the settings for the "Symbol/Product Limits" are for All Symbols (as noted at the top of that page as "ALL_SYMBOLS".
To get a different set of limits for a specific symbol, you need to add that symbol to the list at the top by selecting the symbol in the list at the entry for "New Symbols to Add" (refer to the image we have attached) and then selecting the "Add" button.
The symbol you added will now be selectable at the top and you can set different settings for it.
imageSymbolProductLimits.png / V - Attached On 2024-02-02 17:22:47 UTC - Size: 91.62 KB - 58 views
