Date/Time: Wed, 27 Nov 2024 04:35:26 +0000
Working with Tool.FontBackColor
View Count: 948
[2014-08-03 10:31:44]
Herb - Posts: 9
When working with the text tool I can set FontBackColor to something and modify the text
later with another FontBackColor. But when I want to modify the text and set the
FontBackColor to neutral (initial value 0xff000000) it does not change the background. The
workaround that I found is to delete the drawing first. I there a better way to do it?
[2014-08-03 20:08:51]
To change the s_UseTool::FontBackColor it must be set to an actual color value. There is no way to change it back to default.
Date Time Of Last Edit: 2014-08-03 20:09:11
