Date/Time: Mon, 25 Nov 2024 20:53:14 +0000
replay
View Count: 171
[2024-02-02 07:00:39] |
sahandprs - Posts: 11 |
I have a problem when I want to replay. I have a chart book that consists of different charts. When I want to hit pause and go to see another tab from the same chart canvas, I realize that it has been played. Even when there is a bridge, I realize that it has gone much further, although when I go back to the previous tab, I realize that it is still in the same place as before. what should I do. This makes me unable to replay properly.
Date Time Of Last Edit: 2024-02-02 07:04:23
Screenshot 2024-02-02 at 10.33.08.png / V - Attached On 2024-02-02 07:03:59 UTC - Size: 69.05 KB - 44 views Attachment Deleted. |
[2024-02-02 14:36:59] |
User43 - Posts: 101 |
Well, you have selected to Replay all Charts in chart book. If you only want to replay the current chart then switch the top left drop down box "Charts to Replay:" to "single chart". If you want to only replay selected charts in the chart book then link them at first and use "Charts with Same Link Number" I assume when you refer to "chart canvas" you mean a "chart book". To avoid confusion its best to stick to the Sierra Chart naming of things. |
[2024-02-02 16:51:37] |
John - SC Support - Posts: 36278 |
Also refer to the following: Replaying Charts: Preventing Loss of Synchronization Between Different Charts During Replay For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
