Date/Time: Mon, 25 Nov 2024 20:37:56 +0000
Pivots
View Count: 313
[2024-02-02 06:21:47] |
User575399 - Posts: 322 |
Hello, how come Sierra charts daily pivots differ from Thinkorswims pivot points ? Is there any way to get them closer to TOS’s? I can provide pics if you need. I’ve messed with every setting |
[2024-02-02 16:13:43] |
John - SC Support - Posts: 36278 |
We can not say and it is not something we would look into. There are 29 different formulas that you can use with our Pivot Points study. It could simply be that you are not using the one that matches ThinkOrSwim. Refer to the information here: Pivot Points: Formula Types For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-02-02 16:46:17] |
Not surprising you wont look into it.
[2024-02-04 06:00:56] |
Sierra_Chart Engineering - Posts: 17174 |
We have a whole section which documents this here: Pivot Points are not Accurate or are Different Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
