Date/Time: Mon, 25 Nov 2024 20:31:05 +0000
Usage time
View Count: 164
[2024-02-02 05:45:59] |
Jimmyy - Posts: 221 |
Hello, I am little confused in regards to how much usage time I have left. In my account its saying my usage will expire on 4th Feb but I had also opted for Evaluation of package 12 and its saying my evaluation will expire on 25th feb. Thank you.
[2024-02-02 16:11:34] |
John - SC Support - Posts: 36278 |
Your Usage Time will end on February 4, 2023. Your Evaluation of Package 12 is an Evaluation and not a trial. Meaning that you need to have a valid package in order to have access to the Package 12 features. So if you do not renew your account on February 4, 2024 then you will not have any package available and you will be in "Free Mode". Note, however, that your account is already setup to be on Package 12 for your main subscription, so you do not need the evaluation of Package 12. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
