Date/Time: Mon, 25 Nov 2024 20:49:41 +0000
Data still delayed
View Count: 222
[2024-02-01 17:22:54]
User645637 - Posts: 4
I purchased the integrated package 11 and have connected Denali (total view stock data) but the data is still delayed. I have allowed support for sierra chart data feeds and reconnected the connection. The chart does have the "M" but it is still delayed.
[2024-02-01 19:47:11]
John - SC Support - Posts: 36278
Make sure you are selecting/entering the symbol with the -NQTV suffix (IBM-NQTV). This tells the system that you are wanting the data from our NASDAQ TotalView exchange. Otherwise, if you enter the standard stock symbol (IBM), then that will give you the data for the U.S. Equities Consolidated Tape, which will be delayed since you do not have that exchange active.
[2024-02-01 20:28:08]
I have tried that (AAPL-NQTV). The time and sales window and DOM is real time but the charts are not.
Date Time Of Last Edit: 2024-02-01 20:43:11
[2024-02-01 21:44:51]
Please give us an image of the chart by following these instructions:
And also get us your Message Log by following these instructions:
Close all of the Chartbooks with "File >> Close All Chartbooks".
Open a single chart for the symbol you have an issue with through "File >> Find Symbol". Tell us that symbol of the chart. Tell us about *one* symbol only.
