Date/Time: Mon, 25 Nov 2024 20:28:35 +0000
[Programming Help] - Request for ASCIL Code
View Count: 279
[2024-02-01 17:19:24]
User719760 - Posts: 6
I have tried implementing this way but it is placing orders even when I am not in position.
Can You please share me the full code.
#include "sierrachart.h"
SCDLLName("Target with SLs")
SCSFExport scsf_TargetStopLossInTicks(SCStudyInterfaceRef sc)
static bool ordersPlaced = false; // Static variable to track if orders have been placed
if (sc.SetDefaults)
// Set the study name and other properties
sc.GraphName = "Target and Stop Loss in Ticks";
sc.StudyDescription = "Place target and stop loss in ticks for working orders";
sc.AutoLoop = 1;
sc.FreeDLL = 1;
// Define inputs for target and stop loss in ticks
sc.Input[0].Name = "Target in Ticks";
sc.Input[0].SetInt(70); // Set a default value
sc.Input[1].Name = "Stop Loss in Ticks";
sc.Input[1].SetInt(40); // Set a default value
return;
s_SCPositionData PositionData;
if (sc.PositionData.PositionQuantity >= 1)
// Check if orders are already placed
if (!ordersPlaced)
// Create an s_SCNewOrder object.
s_SCNewOrder NewOrder;
NewOrder.OrderQuantity = 1;
NewOrder.OrderType = SCT_ORDERTYPE_LIMIT;
NewOrder.TextTag = "Position Taken of 1 Qty";
NewOrder.TimeInForce = SCT_TIF_GOOD_TILL_CANCELED;
NewOrder.Stop1Offset = sc.Input[1].GetInt() * sc.TickSize;
NewOrder.Target1Offset = sc.Input[0].GetInt() * sc.TickSize;
// Place the orders
sc.SellEntry(NewOrder);
sc.BuyEntry(NewOrder);
// Set the flag to true to indicate that orders have been placed
ordersPlaced = true;
else
// Reset the flag when there is no position
[2024-02-01 20:11:26]
ForgivingComputers.com - Posts: 960
I see an issue here. You need to use sc.GetTradePosition():
// Need to get the trade position before you can use Position Data
sc.GetTradePosition(PositionData);
[2024-02-02 13:21:05]
emmanuel - Posts: 58
The position quantity is > 0 when there's a long position and < 0 when there's a short position. See Automated Trading From an Advanced Custom Study: s_SCPositionData Structure Members
Use: if (PositionData.PositionQuantity != 0)
`if (!ordersPlaced)` always returns false because the state of the `ordersPlaced` variable is not retained between invocations of the study function. Use a persistent variable instead: See Persistent Variable Functions
if (sc.SetDefaults)
// There are no bool persistent variables. Use an int.
int& ordersPlaced = sc.GerPersistentInt(1);
return;
if (sc.SetDefaults)
return;
