Date/Time: Mon, 25 Nov 2024 20:40:39 +0000
Price line is not in par with Candlestick
View Count: 199
[2024-02-01 17:17:02]
Gravity369 - Posts: 17
Please find attached Screenshot of MNQ. The price line is way above the Last price shown on the scale.
regards
Naga.
imageScreenshot 2024-02-01 100828.jpg / V - Attached On 2024-02-01 17:16:56 UTC - Size: 175.95 KB - 43 views
[2024-02-01 17:18:13]
John - SC Support - Posts: 36278
Are you using the "Current Price Line" study? If so, what are the following Inputs set to:
- Input Data
- Number of Bars Back to Reference
[2024-02-02 18:30:38]
The reason you have a difference is because you are using the "Number of Bars Back to Reference". Refer to how this works at the following link:
Current Price Line: Inputs
