Date/Time: Mon, 25 Nov 2024 20:44:51 +0000
Diagnoal coloring in number bar
View Count: 218
[2024-02-01 17:11:16] |
User102585 - Posts: 4 |
Good afternoon. I have column 2 text coloring set to Diagonal dominant ASK/Bid actual. Some negative numbers color green, some positive numbers color red or white. Any way to get the colors to match the actual number? If it's positive, I'd like green, if it's negative, I'd like red. Not sure if the coloring of the volume profile in column 1 is messing it up? Thanks. https://www.sierrachart.com/image.php?Image=1706807376784.png |
[2024-02-01 19:38:40] |
John - SC Support - Posts: 36278 |
Keep in mind the coloring is completely separate from what is displayed. What is the setting for how the numbers are displayed (i.e. what is the setting for Column 2 Numbers Bars Text)? If you are wanting "Up" colors for positive numbers and "Down" colors for negative numbers, then you will need to align what is displayed with how it is colored. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-02-01 20:06:25] |
Have all the Column 2 Range up colors set to green, all Column 2 range down colors set to red. Column 2 text coloring is set to Diagonal dominant ASK/Bid actual. The numbers are correct, but some of them have negative numbers but are coloring green or white, while positive numbers are sometimes red or white. https://www.sierrachart.com/image.php?Image=1706807376784.png |
[2024-02-01 21:39:32] |
What is your "Column 2 Numbers Bars Text" set to?
[2024-02-01 22:01:39] |
It's set to Ask Vol Bid Vol Diff Diagonal Side
[2024-02-01 22:36:08] |
If it is set to "Ask Vol Bid Vol Difference Diagonal 1 Side" then there is not a text coloring option that will do what you want. We do not have a coloring option that only takes into account the one side. Keep in mind the "Ask Vol Bid Vol Difference Diagonal 1 Side" only gives you the Bid side Diagonal Difference. It is not the Dominant side. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-02-02 14:27:42] |
Got it, thanks.
