Date/Time: Mon, 25 Nov 2024 20:46:33 +0000
Volume by Price - hide all evening sessions
View Count: 166
[2024-02-01 15:47:46] |
joshtrader - Posts: 488 |
Is there a way, while showing the full session time, to show daily profiles for the day session only? I know I can hide all except the last, but I'd like to not even show that one.
[2024-02-01 16:30:42] |
John - SC Support - Posts: 36278 |
There is not a way to turn off the last day's evening session. But what you can do (depending on how you are coloring your bars) is to change the color for the Evening Session bars to be the same as the background so you will not see it. Refer to the following: Volume By Price Study: Displaying Separate Profiles for Day and Evening Sessions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-02-01 17:01:27] |
Thank you. This won't quite work for my case because I am showing not just the profile, but value area lines, and the color of these is fixed and can't be set separately based on day/overnight. I know you're busy but maybe you could consider an option to just not show any evening session profiles. Either way, thank you for your response. |
