Date/Time: Mon, 25 Nov 2024 20:41:47 +0000
Color main graph bar using state of previous bar close (instead of current bar open)
View Count: 162
[2024-02-01 12:50:28] |
funbun - Posts: 90 |
Main graph uses C > O to paint green and C < O to paint red. How do I change it to C > C[-1] for green and C < C[-1] for red? |
[2024-02-01 15:45:40] |
John - SC Support - Posts: 36278 |
Refer to the following setting: Graphics Settings: Up/Down Coloring for OHLC Bars Based on Previous and Current Close (Global Settings >> Graphics Settings >> Other) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
