Date/Time: Mon, 25 Nov 2024 20:24:43 +0000
Settings
View Count: 137
[2024-02-01 11:18:35] |
KevinDiard - Posts: 18 |
Hello, Can you tell me what setting to make to move the graph back to the left. The volume profile hides the graph and I couldn't find the setting to move the graph back Thanks |
sierra plateforme.png / V - Attached On 2024-02-01 11:17:40 UTC - Size: 84.7 KB - 44 views |
[2024-02-01 15:42:20] |
John - SC Support - Posts: 36278 |
We think you are looking for "Lock Fill Space". Refer to the following: Working With Charts: Locking the Right Side Fill Space For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
