Date/Time: Mon, 25 Nov 2024 20:53:34 +0000
OHLC BARS
View Count: 318
[2024-02-01 01:21:45]
clibanez - Posts: 10
Hello, I want to use the bars but make them look one color when the price goes up and another when it goes down.
I know it's with the heikin-hashi studio but I can't configure it that way.
imageheiki.png / V - Attached On 2024-02-01 01:21:22 UTC - Size: 305.56 KB - 52 views
[2024-02-01 15:23:22]
John - SC Support - Posts: 36278
We are not sure exactly what you are looking for, but here are some thoughts.
If you want the bars to be completely red or completely green then make sure the option for "Global Settings >> Graphics Settings >> Other >> Color Entire OHLC Bar the High/Low Color" is enabled. Refer to the following:
Graphics Settings: Color Entire OHLC Bar the High/Low Color (Global Settings >> Graphics Settings >> Other)
If you are wanting to use the Heikin-Ashi Study, then refer to the following:
Heikin-Ashi
[2024-02-01 15:37:29]
it works thank you!
