Date/Time: Mon, 25 Nov 2024 20:43:26 +0000
NO MBO
View Count: 205
[2024-02-01 00:03:00] |
H3R000 - Posts: 7 |
Hi, I got issues with displaying the MBO. I followed the steps from manual and guide on Sierra Chart YT Channel. In screenshots you can see all my settings. Also i have the 12 package. Thank you |
sierradom.png / V - Attached On 2024-02-01 00:02:08 UTC - Size: 886.07 KB - 57 views Attachment Deleted. |
[2024-02-01 15:19:03] |
John - SC Support - Posts: 36278 |
That does not look like the correct column. You need the "...Market Orders Column" to display the MBO data. Make sure you have the correct column. Refer to steps 7, 8 at the following link: Market By Order Data: Step-by-Step Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
