Date/Time: Mon, 25 Nov 2024 18:40:11 +0000
Which package do I need for footprint on /ES?
View Count: 883
[2024-01-31 21:10:56] |
z423jumper - Posts: 4 |
I need to get the footprint/DOM/VP on /ES, but don't know which package I need to get to get that on my charts?
[2024-01-31 21:11:36] |
[2024-02-01 05:14:25] |
Sierra_Chart Engineering - Posts: 17174 |
Do you require real-time data for ES futures?
[2024-02-04 23:13:01] |
User4173000 - Posts: 3 |
Hello, I also need footprint for /ES with real-time data. I am currently on package 11
[2024-02-05 04:32:34] |
Yes I need footprint Dom and real time data - what package is it and how much is it per month?
[2024-02-05 06:57:53] |
fried4104 - Posts: 66 |
You would need package 11. It's 36.8 USD/Month (20% discount applied for 6 month). Add to this the level 2 market depth for DOM as non-professional to trade CME, for 12.5 USD/Month. Totally game changer, you would have the best tools available. Good luck! |
[2024-02-05 17:40:26] |
John - SC Support - Posts: 36264 |
This is supported. You just need to use the Numbers Bars study: Numbers Bars Note that the Level 2 Market Depth data is NOT required for the Numbers Bars study. The Numbers Bars uses actual trades for the information. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-02-05 18:04:01] |
OK so I only need package 11 for numbers bars study and real time /es data right?
[2024-02-05 18:15:31] |
Yes, you would need to be on Package 11 in order to have access to the Numbers Bars study and the real-time data for the ES.
[2024-02-05 22:19:41] |
John, thanks for the confirmation that I have the correct package. What symbol should I use in order to view the realtime ES? I have found many outdated answers on the support board that have lead to a dead end. Also when I go to find symbol I can't find ES
[2024-02-06 09:43:12] |
User727034 - Posts: 21 |
Ref: Yes, you would need to be on Package 11 in order to have access to the Numbers Bars study and the real-time data for the ES. If using delayed data can one use Package 10 for the Numbers Bar study? |
[2024-02-06 16:21:20] |
If you need just delayed data you can use Service Package 5.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-02-06 16:21:33
[2024-02-06 16:22:48] |
User4173000: The symbol for ES depends on the Current Selected Service you are setup for. Each service uses a different symbol. For instance, if you are setup for "SC Data - All Services" then you would use "ESH24-CME" where H is the current contract and 24 is the year. The best thing to do is to use "File >> Find Symbol" and open the section for CME Futures. Look for the "S&P 500" to find what you are looking for. Refer to the following: File Menu: Find Symbol (File) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-02-06 17:12:41] |
John, Again thanks for your reply. As I mentioned, there is no mention of ES or Futures in my "find symbol" window. Is there a link with instructions on how to introduce this into my find symbol window?
[2024-02-06 17:14:58] |
This is because you are using BitMex. Install another copy of Sierra Chart: Using Multiple Data and Trading Services at the Same Time Set the Current Selected Service to SC Data-All Services. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
