Date/Time: Mon, 25 Nov 2024 21:52:39 +0000
Customizing anchor options for rectangle tool
View Count: 158
[2024-01-31 16:14:14]
User588728 - Posts: 4
The only width options for the rectangle tool are in 5 min increments on a 5 min chart. Can they be set to 2.5 increments? When I manually adjust the anchor points to be between 5 min the rectangle still starts/ends at closest 5 min interval.
[2024-01-31 18:10:18]
John - SC Support - Posts: 36281
All drawing tools set the anchors at the bar period times (x) and the Tick Size (y). This can not be changed it is how Sierra Chart is setup.
