Date/Time: Mon, 25 Nov 2024 21:49:08 +0000
Buttons and charts have gone big
View Count: 172
[2024-01-31 14:25:15] |
Baxterkd - Posts: 2 |
Overnight my buttons and charts have all increased in size dramatically. I can not get them to change back and it is not really a usable platform right now. I can not get the bottom menu either so I can scroll between charts. I can also no longer right click on the charts to open trades. Hopefully I have captured the proper image. Thank you. https://www.sierrachart.com/image.php?Image=1706710843667.png |
[2024-01-31 17:43:07] |
John - SC Support - Posts: 36280 |
We do not know why, but your "Global Drawing Font" is the problem. Select "Tools >> Tool Settings >> General" and select entry for "Global Chart Drawing Font", you can then select the "Select" button, which will give you the page to change the font, including the Font Size. Refer to the following: Chart Drawing Tools: Global Chart Drawing Font (Global Settings >> Tool Settings >> General >> Drawing Font) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
