Date/Time: Mon, 25 Nov 2024 21:29:39 +0000
what package do i need to get volume profile, order flows, dom ... in real time ?
View Count: 149
[2024-01-31 07:35:46] |
User708843 - Posts: 1 |
hello, im about to buy a package but i dont know which one i have. I would like to have access to real time data on commodities (crude oil, gold..), Forex, and some other stuffs with tools like volume profil, order flows, dom .... Could you help me with this issue ?
[2024-01-31 16:05:40] |
John - SC Support - Posts: 36280 |
To start with, in order to be able to get real-time data for futures (and to be able to connect to a trading account), you would need to be on one of the "Integrated" packages. And since you want "Order Flow" (Numbers Bars), you would also need an "Advanced" package. If you do not need the Market By Order data, then the "Integrated Advanced" package will give you what you need. Refer to the information on the packages at the following link: Description of Service Packages and Pricing: Packages To add funds and select a package follow the instructions at the following link: Sierra Chart Purchase and License Information: Instructions In terms of data for the CME Group, you need to have a live, funded, futures trading account in order to qualify for the non-professional exchange fees. Refer to the information at the following link: Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
