Date/Time: Mon, 25 Nov 2024 20:30:38 +0000
2 Accounts Listed - Can I place a simultaneous trade in both without 2nd chart/instance?
View Count: 190
[2024-01-30 18:50:27] |
User92573 - Posts: 530 |
Dear Support There are quite a few threads on this subject but none seem to quite answer the question so I'll post here hoping for a solution. Using the account selector/drop-down in the Trade Panel - I currently have Sim1 and 2 others. Is it possible to place the trade in both, or even all 3 if the parameters are the same i.e, quantity Parent/Child Prices etc? Many thanks. |
[2024-01-30 18:53:27] |
John - SC Support - Posts: 36278 |
It sounds like you are asking about the following feature: Order Allocation to Trade Accounts If it is not the above, then we need some additional information. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-01-31 20:00:27] |
Yes I think that's the solution John however its a shame someone in support found it necessary to write ... "We care that the functionality works as it is designed and it does. We do not care about all of the trading that you are doing. Once again we do not care! Please do not burden us with this. "
The functionality is understood buts its a little harsh to turn around to long-term users, in fact all users and say "we don't care!" If nothing else Sierra Chart should care and clearly, you yourself do, as can be seen by the excellent support. It's a shame about those sort of comments as there are many dedicated users that constantly argue the benefits of Sierra. Anyway, many thanks once again for great support. Date Time Of Last Edit: 2024-01-31 20:00:55
[2024-01-31 22:54:46] |
You are quite welcome. Thank you for the kind words.
