Date/Time: Sun, 24 Nov 2024 15:56:10 +0000
Dom Graph on Chart - quick question please?
View Count: 851
[2024-01-30 17:12:18]
User666015 - Posts: 49
Hi Support,
Me again I'm afraid!
Very quick one please, I would like to enable Draw DOM Graph on Chart - but I also have a far right aligned volume profile. When the DOM graph is enabled it 'pushes' my volume profile over to the left, is there a way that I can make them overlap?
Screenshot: https://www.sierrachart.com/image.php?Image=1706634573215.png
Many thanks,
Bill
[2024-01-30 18:26:24]
You can not make them overlap, but it looks like your Volume by Price profile has the Input for "Align to Far Right" set to "No". It sounds like you want this set to "Yes" so the profile will be further to the right and not part of the bars. Refer to the following:
Volume By Price Study: Align to Far Right
Also, you can control the size of the DOM Graph by setting "Chart >> Chart Settings >> Market Depth >> Width in Bars". Refer to the following:
Trade Menu: Draw DOM Graph on Chart (Trade menu)
[2024-01-30 18:30:09]
Thanks John, the profile is set to Align to Far Right - it still gets moved to the left when the DOM graph is enabled.
I believe you guys are working on a setting to align the volume profile to far left, this will solve my problem as I'll move them over the make room.
Cheers,
Bill
[2024-05-21 20:50:13]
mandano89 - Posts: 24
Yes you can overlap the VbP Chart with the DOM Graph Bars! The Bars are part of the DOM Graph so you need to set the VbP Study option "Do not overlap DOM Graph" to "no"
[2024-05-21 21:31:35]
mandano89, you are correct. We forgot about that setting and we were thinking of the DOM itself, not the "DOM Graph". Thank you for pointing this out.
