Date/Time: Mon, 25 Nov 2024 21:23:09 +0000
ver ventanas por separado
View Count: 168
[2024-01-30 14:53:16] |
luciana - Posts: 24 |
Hola, quisiera saber como puedo separar estas dos pestaƱas para visualizar ambas al mismo tiempo. Ahora solo me permite tener una a la vez abierta. Gracias |
422903437_10168629102340046_4455050468687599714_n.jpg / V - Attached On 2024-01-30 14:52:39 UTC - Size: 1019.71 KB - 47 views |
[2024-01-30 17:11:43] |
John - SC Support - Posts: 36279 |
From Google Translate: I would like to know how I can separate these two tabs to view both at the same time.
Now it only allows me to have one open at a time. Those are the Chartbooks. In order to have chartbooks in separate windows, you would need to use a Sub-Instance. Refer to the following: File Menu: New Instance (File) Keep in mind, when you first create a sub-instance, it will copy the files from the Main Instance. But this only occurs this one time. From that point forward the data in each instance is its own data. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
