Date/Time: Mon, 25 Nov 2024 22:02:15 +0000
VWAP study is missing on the chart
View Count: 197
[2024-01-30 14:40:49] |
pennydoll9 - Posts: 20 |
Support Team, I have the VWAP study added into the chart but the study is not visible on the chart. Can somebody please help with this issue? Thanks |
[2024-01-30 17:57:51] |
John - SC Support - Posts: 36283 |
Which VWAP study are you using? The one thing we can think of, offhand, is to make sure the scaling for the study is set to "Automatic" or "Same as Region". Refer to the following: Chart Scale and Scale Adjusting: Opening the Scale Settings Window For a Study For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-01-30 19:48:24] |
"Same as region" was I had initially and the VWAP is not visible and when I switch to "Automatic" , the VWAP is visible but the line has lot of deviation than the original VWAP line
[2024-01-30 22:23:53] |
What do you mean it has a lot of Deviation? Please give us an image of what you are seeing by following these instructions: Support Board Posting Information: Attaching or Posting a Screenshot/Image (Optional) Also, what VWAP study are you using? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
