Date/Time: Mon, 25 Nov 2024 21:32:02 +0000
Tick size on BTCUSD numbers chart keeps reverting back to a really low number
View Count: 301
[2024-01-30 04:02:44] |
User244241 - Posts: 2 |
Hi I am trying to set up an orderflow chart on binance btcusdt but the tick size doesn't seem to want to change. Its set to 0.010000 at the moment and all I see is dashes. However everytime I change it to a higher number (say 30 for example) and click Apply All, it updates the bars for a millisecond and then reverts back to 0.010000. |
[2024-01-30 05:29:22] |
Sierra_Chart Engineering - Posts: 17175 |
Follow the instructions here for this: Cryptocurrency / Bitcoin Data and Trading Services: Important: Volume at Price Studies with Cryptocurrency Symbols Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
