Date/Time: Fri, 22 Nov 2024 11:02:33 +0000
[Feature Request] Alerts speaking over each other
View Count: 221
[2024-01-30 03:02:26] |
cesium - Posts: 85 |
Hello John Hello Engineering Team, Is there a way to have sierrachart play multiple alerts at the same time as they are triggered, instead of having to choose between either waiting for the que or cutting off the alert currently triggered? In essence, alerts would be "talking over each other". If not, what would a timeline be for this feature request, if any? Thank you |
[2024-01-30 15:35:09] |
John - SC Support - Posts: 36203 |
This would be a feature request. We can not say when we can get to any particular request. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-10-09 02:26:39] |
User839162 - Posts: 87 |
Any progress on this? This would be a fantastic addition. It would allow users to build out multiple order alerts similar to PriceSquawk or TickStrike.
[2024-10-09 16:03:28] |
Somehow we forgot to mention the following setting, which allows this to occur: General Settings Window: Wait for Prior Alert Sound to Finish Before Playing Next Queued Sound (Global Settings >> General Settings >> Alerts >> Additional Settings) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-10-09 17:20:48] |
Thanks @John. Although when I use this setting, it's still slow to play alerts. For example, I would like to set up alerts to play for all time and sales orders (to get a sense of pace of tape). When I try to do this each order get's played individually and not all at once.
[2024-10-09 18:20:13] |
This is an item that would require us to put some time into it. Hence the original statement of this being a Feature Request. We just can not say when we would be able to get to this. But we have noted the request.
