Date/Time: Mon, 25 Nov 2024 21:54:54 +0000
URGENT:sc no longer allows new symbol
View Count: 275
[2024-01-29 21:59:56]
User472677 - Posts: 350
For years I have been able to enter new symbols in sc windows. Support symbol entry in chart window is enabled. It worked fine most of the day. Starting about 3 pm I can no longer enter a new symbol in any chart window.
I restarted. Problem persists.
[2024-01-29 22:06:12]
Please help urgently since I have positions. Can you login and fix it.
[2024-01-30 05:22:36]
Sierra_Chart Engineering - Posts: 17175
Make sure this option is enabled:
General Settings Window: Support Symbol Entry from Chart Window (Global Settings >> General Settings >> Charts >> Symbol)
Keyboard shortcuts could also be interfering. Those are configured through Global Settings >> Customize Keyboard Shortcuts.
[2024-01-30 13:17:10]
This is URGENT as it is affecting my trading.
As stated in the original post, "Support symbol entry in chart window is enabled"
I have never set up any keybord short cuts.
Please note from the original post, "It worked fine most of the day. Starting about 3 pm I can no longer enter a new symbol in any chart window.
Please help immediately to fix it.
[2024-01-30 16:51:58]
John - SC Support - Posts: 36282
There is no reason for this to simply stop working. Please select the "Escape" key a few times to make sure the queue is empty and then try typing a symbol again. Be sure to select the "Enter" key at the end of the entry.
