Date/Time: Mon, 25 Nov 2024 22:40:57 +0000
transfer my charts i created on my chartbook to a laptop
View Count: 159
[2024-01-29 18:33:12]
cruxstock - Posts: 6
hello quick question is it possible to transfer my charts i created on my chartbook to a laptop, if so can it be an apple laptop or do i need microsoft. thank you
[2024-01-29 19:45:34]
John - SC Support - Posts: 36284
Sierra Chart is only made to run on Windows. People do run it on MAC OS, but you have to use an emulator to do so, and this is not something we can help with. There are a few posts in this Support Board on this topic.
As to transferring chart, all you need to do is to copy the Chartbook files to the other computer. Refer to the following, which also gives instructions on transferring all the settings from one computer to another - use whatever pieces you need:
Transferring Sierra Chart Settings and Data From Existing Installation to New Installation: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation
