Date/Time: Mon, 25 Nov 2024 22:42:19 +0000
Trade simulator
View Count: 166
[2024-01-29 17:01:55] |
User611660 - Posts: 6 |
How do I trade with the trade simulator within Sierra Charts? I followed the instructions on the support board and clicked the appropriate chart but the simulator is not coming up. Can you help?
[2024-01-29 19:27:45] |
John - SC Support - Posts: 36284 |
What do you mean the "simulator is not coming up"? There is nothing to come up. If you are in Simulation Mode in the system, then your trading is all simulated. Refer to the following: Trade Simulation And there is also our "Simulated Futures Trading Service" that is a bit more realistic in how it works. Refer to the following for this: Trade Simulation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
