Date/Time: Mon, 25 Nov 2024 22:26:43 +0000
Volume Profile Drawing Tool - Can't change settings
View Count: 200
[2024-01-29 16:39:12]
User708541 - Posts: 87
When I use the Draw Volume Profile tool it will not adhere to the settings I've set up under the tool setting menu. It uses a different set of settings that I can't figure out how to change - Or I can change them but the settings wont stick. The tool always reverts to some other settings.
Also, unlike other tools, a right click on the tool won't allow me to access the Chart Drawing Properties (it's greyed out).
I'm using version 2590 if that helps.
Thanks for your help.
[2024-01-29 19:05:09]
John - SC Support - Posts: 36283
Refer to the following for how to setup the configuration for the Draw Volume Profile tool:
Volume By Price Study: Step by Step Instructions to Configure the Draw Volume Profile Tool
Since you are creating a custom Volume by Price profile with the Draw Volume Profile tool, the "Chart Drawing Properties" is not available. But you can right-click and select Volume Profile Settings, which will get you to the Settings for the volume profile.
[2024-01-29 19:26:37]
Yes, I've done all that.
But once I change the settings, the settings will not stay (stick). So, the next time I draw a Vol Profile, it uses some other settings.
[2024-01-29 19:34:09]
Support,
I was able to get the configuration to save. It works now. Thank you.
