Date/Time: Mon, 25 Nov 2024 22:49:49 +0000
Drawing Reruest Tran
View Count: 179
[2024-01-28 21:19:23] |
Bruce - Posts: 47 |
can you please add Transparent Fill Rectangle Top and bottom to Use Multicolumn Rectangle Style For Price Bars...Currently you have Use Filled Rectangle and use Hollow Rectangle in the drop down. i Tried changing it in the Subrgaph, but it just pops back to fill Rectangle top and bottom
Date Time Of Last Edit: 2024-01-29 13:20:57
Private File |
[2024-01-29 17:57:37] |
John - SC Support - Posts: 36286 |
The Top and Bottom fill styles will not work for the "Multicolumn Rectangle Style for Price Bars", as those draw differently from what this particular setting does.
[2024-01-30 01:14:16] |
Bruce - Posts: 47 |
Thanks for your responce, if you looked at my attached image, i was referring to the Top Rectangle fill and the bottom rectangnle fill or a hollow rectangle fill for the Multicolumn Rectangle Style For Price Bar. But you also have a Transparent rectangle fill for top and bottom, I would like for you to add that as another option to the drop down nmder the Multicolumn Rectangle Style For Price Bars. My image above show only 2 options for Multicolumn Rectangle Style For Price Bars, since you have a Transparent Rectangle fill,why not add that as a 3rd option. Please Thank you Date Time Of Last Edit: 2024-01-30 01:15:12
