Date/Time: Mon, 16 Sep 2024 19:12:43 +0000
Quote Spreadsheet Row Limitation and ACSIL sc.GetBasicSymbolData query
View Count: 284
[2024-01-28 18:52:38] |
User150671 - Posts: 63 |
Good Morning, I have noticed that Quote Spreadsheets will not get quotes for symbols past row 1001. Is this by design? I am trying to process between 1.5-2k quote symbols through Sierra into an an external application using the Spreadsheet Study as an in between. I can obviously do this using two spreadsheets and studies if needed, but wondered if it was by design, or maybe a hang over from the old spreadsheets which had limited rows IIRC. Semi-Related question regarding ACSIL as an alternative method: If I created a ACSIL study which, on initial run only, iterated over a list of these quotes and called sc.GetBasicSymbolData with the SubscribeToData flag set on each one, would the end result be that a SCID file was created and updated for each symbol until sierra exited? This would be ideal. EDIT: I did not realise that Global Settings > Intraday File Update List existed. I can simply spit out a symbol list from my application - load it into the Intraday File Update List, and then get a ridiculous amount of SCID files to iterate on. This is perfect. Date Time Of Last Edit: 2024-01-28 20:37:01
[2024-01-28 22:24:15] |
Sierra_Chart Engineering - Posts: 16387 |
I have noticed that Quote Spreadsheets will not get quotes for symbols past row 1001. Yes but we will increase this to 2000.Is this by design? Yes: I did not realise that Global Settings > Intraday File Update List existed.
I can simply spit out a symbol list from my application - load it into the Intraday File Update List, and then get a ridiculous amount of SCID files to iterate on. This is perfect. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
