Date/Time: Mon, 25 Nov 2024 22:39:34 +0000
stock charts for s@p and nasdaq
View Count: 191
[2024-01-28 16:22:43] |
User596209 - Posts: 12 |
can I get stock charts on my trading platform if so how would I do it
[2024-01-29 17:19:13] |
John - SC Support - Posts: 36284 |
You can get stock data from us. If you want delayed streaming data, then you just need to open a chart for the symbol you want (e.g. IBM). You will get the data delayed by 15 minutes. If you want real-time data, then you need to decide what exchange you want. We have the following: - U.S. Equities Consolidated Tape: Full volume and price action for all exchanges on which a stock trades. Does not have Market Depth Data. Uses standard stock symbols (IBM) - NASDAQ TotalView: Only volume and pricing for the NASDAQ exchange. Does have Market Depth data from the NASDAQ exchange. Uses the suffix -NQTV (IBM-NQTV) There is also the option to combine these two by activating both and then using the suffix _MBO (IBM_MBO) which will give you the full volume and price information with the Market Depth from the NASDAQ exchange. To activate the exchange(s) you want, follow the instructions at the following link: Denali Exchange Data Feed: *Setup Instructions: All Other Exchanges* --- Separately, we noticed that you have both the following exchanges active: - Full CME Group (CME, CBOT, COMEX, NYMEX) with Market Depth for non-professional Trading accounts - Full CME Group (CME, CBOT, COMEX, NYMEX) for non-professional Trading accounts You do not need both of these. Choose the one you want and deactivate the other. Be sure to do this prior to February 1, 2024 so you do not pay for the exchange you do not need when they renew on that date. You can modify your exchange selections at the following link: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed#Exchanges For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
