Date/Time: Mon, 25 Nov 2024 22:31:07 +0000
alerts
View Count: 174
[2024-01-28 05:38:09]
User220637 - Posts: 10
can I receive an alert for a closed 5min bar with higher than usual volume near a line a drew? thank you
[2024-01-29 16:52:56]
John - SC Support - Posts: 36284
This is possible, but we would need more information to give you specifics.
In general, though, refer to the following:
Study/Chart Alerts And Scanning
[2024-01-29 17:11:06]
Here are 3 pics, I draw a line and if the 5min candle closes exactly or around the level and the volume is higher than usual a signal is generated. Thank you
imagepic.1.png / V - Attached On 2024-01-29 17:10:23 UTC - Size: 55.34 KB - 52 views
imagepic.2.png / V - Attached On 2024-01-29 17:10:39 UTC - Size: 57.18 KB - 59 views
[2024-01-29 17:11:44]
here s the 3d pic
imagepic.3.png / V - Attached On 2024-01-29 17:11:18 UTC - Size: 122.44 KB - 57 views
[2024-01-29 19:33:28]
The general alert condition for when the price goes up across the line and the volume of the bar is greater than 500 would be the following:
=AND(C > UDID[10][0], V > 500)
Where [10] is the ID of the line and [0] is the bar offset from the current bar. Refer to the following:
Study/Chart Alerts And Scanning: Reference by Bar Value
Study/Chart Alerts And Scanning: Available Main Price Graph Identifiers/Variables
